Save Formit Back to Revit Greyed Out
cwinchester.hmc
cwinchester.hmc
There appears to be a bug where the "save Formit back to Revit" button in Formit stops working and becomes greyed out. It was working in my current session without closing and now is no longer active. Please advise as to how this bug can be repaired. Thanks.
josh.goldstein
Hi Cody,
If you close the Revit session from which FormIt was launched, or open a different Revit project in the same window, the Send to Revit button will be disabled because the Revit session it was sending to is no longer available.
You can always launch a new FormIt session via the 3D Sketch button from the current Revit project. You can also copy and paste-in-place the data from the disconnected FormIt session to the connected one, or save the FormIt model in the disconnected session, and reopen it in the connected one, to continue working.
Josh Goldstein
Senior Product Manager
cwinchester.hmc
The session never closed, so this is not the case. I had deleted geometry in the active Revit file to make way for an update in the still active session of Formit. Perhaps this is where the glitch exists. The solution probably needs to be a live linkage of the Formit Sketch.
