Please help with "File Open Error"
I have used for it on my iPad for a while now. Today however, I ran into a problem that I can't figure out. Some of my documents, including one I was working just yesterday, now say "File open error could not open file" every time I try. Also, instaid of a little picture their picture is gray. How can I fix this I really need those projects, this has never happened before.
Tobias_Hathorn
Sorry to hear that! It sounds like a few of your files may have become corrupt - though not sure that's the issue.
If you're saving your files on A360 Drive, then you can roll back to a previous revision of the file.
  • Go to A360 Drive - https://360.autodesk.com/
  • Log in with the account you used on your iPad FormIt App
  • Go to the FormIt folder
  • Find the file you're having issues with
  • Expand the list of actions for this file and find 'Versions' - you'll see the dialog in the attached screenshot
  • Then choose the most recent revision before the current one and click the clock icon - then click 'Revert'
  • If you want to go back to the current version then follow these same steps again
Give this a try - let us know if you're still stuck. You can share the file with us and we can see if we can help!
Thanks for the reply. I still however am stuck. For some reason Formit always makes more of things so there are a TON of the duplicates of the broken projects. Also, since I tried to open many things in the 360app and none worked since it said "creating check back soon" and it's been like 3 hours. I can't. Tell which copy is the right one because the broken project is a copy.
hours. I can't tell which copy is the right one to fix because the broken
project is a copy.
