Formit to Revit 2018 Crashes using Add Import Formit to Revit
I am testing Fotmit at the moment using Revit 2018.3.
I have the Ribbon Add In from Formit which in reality should allow me to open my Formit file in Revit but when i try to do this, two things happen:
  1. Revit tries to update the Formit Model from 2016 to 2018
  2. Error comes up asking me to "save File & Continue" or "Continue without saving"
Regardless of which option i chose, nothing happens. The file is like 2MB so I don't believe is file size.
If anyone has had a similar issue and a possible solution, would love to hear from you.
kmfuhrman
Are you using the web version of FormIt, or the desktop version? If you are using the desktop, have you downloaded the latest version, or checked for updates? Same with the add-in?
Kimberly Fuhrman, LEED AP BD+C
Freelance Architectural Technologist
josh.goldstein
Hi Diego,
Errors like this might be the result of trying to send geometry that is not solid or otherwise invalid to Revit. This is especially common if you're working with geometry imported from a SketchUp file.
FormIt has powerful diagnostic and repair tools that reveal issues like nonmanifold edges (edges not contributing to a solid/watertight shape), as well as faces that are flipped the wrong way and faces that are unexpectedly triangulated. Any of these can cause issues when trying to convert to Revit.
Check out this page on how to use these tools to prepare geometry for conversion to Revit. I suspect trying the tips on there will solve your issue. Also, ensuring you have the latest version of FormIt (v16.4) and the Add-In for Revit (v1.9.4) as Kimberly suggested can't hurt either. If you continue to have issues, let us know, and we can take a look at the file to see what's going wrong.
Josh Goldstein
Senior Product Manager
Hi Both,
Thank you for your response.
Kimberly we are using the desktop version and yes we are suing the latest one, as well for the Revit add ins.
The models we are using have not been imported from Sketch Up, these have been created in Formit as we are currently evaluating whether we move from Sketch Up to Formit within the business.
Josh, Ive had a look at the page and tried to follow steps to make sure the model created is imported well to Revit, but there still issues as before.
As we are new to Formit maybe its something silly that we are missing, would love to share one of our models to see if you could assist us in figuring out what we are doing wrong.
Regards
Diego
josh.goldstein
Hi Diego,
We'd be happy to take a look at the model. I'll reach out via private message.
Thanks!
Josh Goldstein
kmfuhrman
Thanks, Josh! Can you please report back when this is resolved? I'd love to hear the solution!
josh.goldstein
Hi Kimberly,
Sure thing, I was planning to update this thread anyway, with Diego's blessing.
Diego sent me the files, and using FormIt's Display Watertight Issues (shortcut DW) and Display Backfaces (shortcut DB) diagnostic modes, the problem was immediately apparent. He gave me permission to post the images of his model and why it was problematic:
Using Display Watertight Issues, the model is very red:
Similarly with Display Backfaces, most of the faces are facing the wrong way:
The majority of the issues are due to a modeling strategy that employs 2D geometry instead of 3D solids. For example, the facade panels are all 2D rectangles which can be problematic for Revit to consume, and also can easily result in flipped faces:
The best modeling advice I can give is to model *everything* as a 3D solid. This is ideal for many reasons: FormIt is designed for solid modeling, downstream applications like Revit or 3D printers are expecting solid geometry, and this strategy best represents real-life assemblies and materials anyway - everything has a thickness, even glass.
If Diego extruded those 2D rectangular faces into 3D blocks, FormIt would automatically flip all the faces of the new solid to orient correctly, the 3D geometry would translate to Revit, and the solid better mimics the real-world object anyway. Doing this would also negate the need to have the 2D banner surface around the window - the solid blocks and a solid backing wall would provide the necessary depth to achieve the same effect. The glass itself should also be extruded slightly to give it some thickness.
We suggest all this and more in this blog post. It's worth a read for anyone else having troubles converting geometry to Revit.
FormIt is designed as a solid modeler, but as Diego demonstrated, you can still create 2D shapes in FormIt that are not solid and won't translate to Revit. SketchUp geometry is notorious for these types of issues because it is not designed for solid geometry and has limited tools for solid modeling.
FormIt has a ton of built-in intelligence to encourage solid modeling, like automatic merge and repair tools that correct face orientation and other issues when extruding 2D shapes into 3D, solid tools like Cover that attempt to automatically close a shape into a 3D solid, as well as the diagnostic modes I mention above. Other FormIt functionality simply works best with solids or requires solids to function: our extrusion tool can do so much more when used with solid geometry, and other tools like 3D Offset and 3D Shell require solids to function at all.
We have some videos we'll be releasing soon that demonstrate the benefits of solid modeling in FormIt, as well as the tools to fix problematic models and tips to keep things solid during the modeling process. Stay tuned.
Hope this helps.
Josh Goldstein
