FormIt Converter failure
nadinepearson
nadinepearson
I've been trying to convert rfa files to the axmf files to use in FormIt Pro.
The converter goes through all of the rfa files and then leaves me with an error message and a link to the results in a .txt file. The file reads as follows below, but does not give any particular information about what the problem was.
Is there a way to fix this?
RESULT
Conversion from RFA to AXMF is FAILED
DETAIL INFO
The following files are not supported and skipped
The following files had problem during conversion
\RPC Beetle.rfa
\RPC Chair.rfa
\RPC Female.rfa
\RPC Male.rfa
\RPC Notebook Computer.rfa
\RPC Picture Frame.rfa
The following files had problem during uploading
The following files were overwritten with the latest version
No permission to read the following files
No permission to read the following directories
I am sorry you are having trouble with the FormIt converter. Unfortunately, RPC families are not currently supported. That error message should be fixed to be more clear. Did it successfully convert any of the other RFA families you had in your  target directory?
nadinepearson
Yes, i've tried a few others and they appear to be working fine.
Is there somewhere that I can get people and trees? I found some items on a previous thread, but I'm hoping there are more available:
https://autodesk.app.box.com/s/thavswirrbflit27rbqzl26ljj7fu1uv/folder/8866009678
tvollaro
The best way to do people and trees is actually to find them on the SketchUp Warehouse Smiley Happy  You can then import them (SKP is the only format we import with materials intact) and then save them out as individual AXM files to be imported using the Content Library. See this webinar video for more details: https://youtu.be/dwJXEpJhphA
Tom Vollaro
Experience Design Architect - Autodesk
