Errorcode The requested resource does not exist
ahoffmanDMX3L
Observer Observer
Message 1 of 16
ahoffmanDMX3L
Observer
Observer
{"developerMessage":"The requested resource does not exist.","errorCode":"","moreInfo":"https://forge.autodesk.com/en/docs/oauth/v2/developers_guide/error_handling/"}
 ^I get this error message on my IPad Pro Gen 5 IOS 17 when I click on the account logo to try logging in… Help without logging in the apps worthless to me.
Replies (15)
Message 2 of 16
josh.goldstein
Hi @ahoffmanDMX3L,
Thanks for bringing this to our attention.
We're investigating and will update here when we know more.
In the meantime, our apologies for the inconvenience.
Josh Goldstein
Senior Product Manager
Message 3 of 16
manaiah_patil
Please let me know if there is any update on this. Thank you
Message 4 of 16
josh.goldstein
@ahoffmanDMX3L,
This should now be fixed.
Would you mind letting us know if logging in works for you?
Josh Goldstein
Message 5 of 16
DsinghLRH36
Community Visitor
Community Visitor
Hello @autodesk Support,
Error getting access token: { "developerMessage": "The requested resource does not exist.", "moreInfo": "https://aps.autodesk.com/en/docs/oauth/v2/developers_guide/error_handling/", "errorCode": "" }
may I know the reason for above mentioned error please.
Message 6 of 16
josh.goldstein
@DsinghLRH36 are you still getting this error? Are there any steps you can share to make it show up?
Josh Goldstein
Message 7 of 16
calvinclark_williams
Community Visitor
Community Visitor
I am getting the same error message:
 "developerMessage":"The requested resource does not exist.", "moreInfo": "https://aps.autodesk.com/en/docs/oauth/v2/developers_guide/error_handling/", "errorCode": ""}
I am new at API programming and trying to get the excel export sample to work with Heroku. The app runs,  and these UI elements appear above, but both Sign in buttons give the above error message. I've confirmed the Forge Client ID and Forge Client Secret keys are added to Heroku as vars. I've created the Custom Integration app in the ADMIN for BIM360.  Thank you in advance for helping.
Message 8 of 16
Gauri.Conrad
Same issue, is the problem from autodesk side, the dashboard shows everything is working? @josh.goldstein @autodesk @DsinghLRH36 @calvinclark_williams
Message 9 of 16
josh.goldstein
Hi @calvinclark_williams and @Gauri.Conrad ,
Can you both clarify the context in which you're seeing this error, and what you're trying to do in FormIt?
An "excel export sample" is mentioned, but the only relevant feature I know of in FormIt is a Dynamo sample which outputs to Excel. Is that what we're referring to here, or something else?
Thanks!
Josh Goldstein
Message 10 of 16
Gauri.Conrad
My company links ACC to our internal software, previously the links were working to import the information from ACC such as Issues,RFIs and checklists(forms). When we click the import button in our software it gives the resource not found error.
Message 11 of 16
josh.goldstein
Are you talking about in FormIt though? Since this is the FormIt forum, I'm trying to understand what specific FormIt feature you're using to get this error. Are you importing models from Autodesk Docs?
Josh Goldstein
Message 12 of 16
loukabardou
Observer
Observer
i got the same problem
Message 13 of 16
loukabardou
Observer
Observer
i tried to send you an email to give your more information about my problem, but didn't work
Message 14 of 16
josh.goldstein
As mentioned above, we need more information.
What FormIt feature are you using to cause this? What steps are being taken? Screenshots or a video would help.
Josh Goldstein
Message 15 of 16
loukabardou
Observer
Observer
yeah sure got more information in this google doc because i can't send it here : https://docs.google.com/document/d/1U4kRVs5_UccwVQp2k-fxV1ymQM9bDWCGTeTesN8WLFs/edit?usp=sharing
Message 16 of 16
josh.goldstein
Sorry, but I think you're in the wrong forum. Several of you may be, since no one except for the original poster has been able to give us anything FormIt-related to work with.
This is the FormIt forum, it's for Autodesk FormIt which is a standalone 3D modeler that has little to do with Autodesk Platform Services.
I don't see a forum specifically for this, but you might try the APS website and contact help from there.
Josh Goldstein
