Cutting component
Cutting component
Cutting component
Is there a way to create a components / group that will cut the face it is applied to automatically? For example I am trying to create a window that will cut out the wall automatically to save time. I know this is possible in sketch up and revit.
josh.goldstein
Hi Anthony,
Thanks for the request. You can't do this in FormIt, yet. We'll add your feedback to our system for a potential future implementation.
In the meantime, you could use FormIt's Smart Selection, Array, and Extrude tools to quickly punch holes in a building shell and then edit all of the opening sizes at once. Combined with Groups, you could accomplish a similar workflow you're after: edit the window Groups and all of the holes at once. Below is a Screencast and a description:
- Use Array (AR) to array a rectangle across the facade
- Use Smart Selection to hover over one of the rectangular faces, then hit Tab to select them all
- Array the row up the entire height of the building
- Use Smart Selection to hover over one rectangle, then hit Tab to select them all
- Click to extrude all the window holes at once
- Create a window as a Group
- Array the window Group to fit into all the openings
- Edit the window size, then exit the Group
- Use Smart Selection to select all the sides and top/bottom faces of the holes to adjust them at once to match the window
Hope this helps in the absence of the feature you're requesting.
Josh Goldstein
Senior Product Manager
