Compass tool?
Compass tool?
Compass tool?
Is there a compass tool or any other way to enter degrees for angles?
Tobias_Hathorn
yes, the rotate tool has a compass built into it so you can rotate by precise degrees.
- select geometry
- right click
- choose the rotate tool (also you can use the Q keyboard shortcut)
- a compass widget appears
- you can pick up the center grip and move it to your desired pivot axis
- then you can grab the blue dot grip and set the origin angle
- then you can grab the arrow widgets and rotate
- you can also hit the tab key to input a specific dimension at any time
- note that this is a 'measure angle' tool as well as a 'mirror' and 'radial array' tool which use the same compass widget
Here is a short video showing the steps I described above
The formit that I have is on the ipad pro it there a way to do the same
Tobias_Hathorn
Yes - you have to access through the context menu as there are no keyboard shortcuts. To do that...
- double tap an object to select it
- press and hold on the selected object for a moment (1 second or so)
- the context menu will appear, and the rotate icon will be present
- tap the rotate icon and you'll see the compass widget appear
- the grips do the same thing as I described previously - center grip moves the pivot axis, blue grip changes the origin of rotation angle, arrows rotate
Hope that helps! Please keep the thread going if not.
Tobias
Im trying to place a 45 on top of a 90
