Change the elevation dimensions of the elements in formit.
f.annoscia1XRNMD
f.annoscia1XRNMD
Good morning.
In Formit when I import some cad files, the elements are placed on different dimensions elevation. Can I change the elevation dimension of elements in Formit?
Immagine 2022-06-15 170644.pngThank you.
lucdoucet_msdl
@f.annoscia1XRNMD
There is no direct control of the elevation of vertices in FormIt. You will need to use the "Move" command on either the selected vertices, edges, faces or whole groups relative to the coordinate origin of the Scene or Group.
When importing geometry from Revit to Formit, the objects relative elevations will be the same with respect to the internal origin of the Revit Project.
Hope this helps,
-luc
