Broken Functionality in Formit Pro
The ability to export images and insights from Formit Pro for windows appears to be broken. In former instance, a file is exported and appears  in A360 but it cannot be viewed. In the latter, no insights are generated from the Energy Analysis menu. Is there an update that fixes these issue that I should install? Is this a none problem at this stage in Formit's development? Thanks.Formit Problems.PNG
josh.goldstein
Hi cwinches,
Sorry for the inconvenience.
It appears exporting an image to A360 Drive from the FormIt for Windows app is not working, as you noted. We'll fix this in a future update. In the interim, you can still export the image locally, then upload it to A360 Drive yourself if that's where you need it to reside.
As for Energy Analysis, there's a known issue where if you've previously run Energy Analysis on the file using the same file name, you'll get an error the next time. Try renaming the FormIt file to a unique name, then running Energy Analysis again. This is also something we'll look at fixing in a future update.
Josh Goldstein
Senior Product Manager
