I set a location, grouped the building, and applied levels. Only the first level is showing an area, the other 3 show zero area. The levels also aren't showing up even though I have checked them off on the Property tab. When I try and run the energy analysis, I get an error saying "Insight project could not be created. Please try again later."
Am I missing a step? Is the energy analysis available for the trial version?
-Alexis
Hi Alexis - I don't think you're missing anything - but there is probably some 'bad' geometry in your model which is causing it to be NOT solid
Try turning on Display Backfaces and Display Watertight issues (DB and DW keyboard shortcuts) - these will turn any 'bad' geometry red
Once you clean up any red highlighted geometry then you should be able to analyze successfully, and import to Revit successfully (and 3d print successfully)
In addition to the suggestions from Tobias, the error you see about failing to create the project suggests an issue with the GBS entitlements for your account.
Please try logging into Green Building Studio directly with the account - https://gbs.autodesk.com/GBS/Project
If your log in is successful, then try again to run energy analysis from FormIt.
Please let us know if you continue to see problems.
Thanks!
-Heather
