Im using formit 360 pro on a windows but my levels wont show, as you can see in the pictures. levels are checked and I have my levels but nothing will show. what am I doning wrong? I dont seem to be able to find the "display levels" as in the web version.
Solved by josh.goldstein. Go to Solution.
Try selecting the Group, then going to Properties (top icon on right side), and check "Use Levels" - this will use any of the Levels you've set up in the Sketch and show them on that object.
Note that you may need to make that geometry solid before Levels will work (by filling in the missing face) - Levels need to be able to accurately "slice" a solid volume to return area.
Hope this helps!
