Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Wind analysis, wind rose not available
5 REPLIES 5
WimDeClerckVKAE
240 Views, 5 Replies
Where can we find a wind rose for a region in Belgium, Europe? And how can i add it to forma ?
Tags (1)
Labels (3)
5 REPLIES 5
There are various resources you can use to find wind rose data. The global wind atlas is a common source for this, though I'm not sure they have detailed enough data for the region your project is in. https://globalwindatlas.info/en/area/Belgium/Vlaanderen
We are currently not yet supporting uploading custom wind roses, but you can input the settings from another windrose into our parameters in the wind analysis and get the correct results that way.
Kind regards, Per
OK, Thank you. The import would be an improvement, but it will do. Stil missing the wind comfort though.
After some more inspection, we have figured out that the vendor we are getting wind roses from is not delivering data for the moment. We are working on fixing it, and when that is solved, you should both get the wind comfort analysis and get the windrose for your area automatically. Sorry about the inconvenience.
Kind regards, Per
Hi again,
The issue with the wind rose data should now have been resolved. Try opening the wind analysis again and it should now give you the full experience.
Kind regards, Per
Perfect !
