Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Unable to update hub settings and delete old projects
2 REPLIES 2
Omer_Barr
120 Views, 2 Replies
I find it impossible to update the hub settings -
Everytime I change them it keeps reverting to the default settings. I tried logging in and out, and using different browsers but it didn't make any difference.
The same thing applies to deleting old projects - I couldn't find a way to delete them so I tried archiving them but they keep popping up back again on the home screen.
Any suggestions on how to resolve this?
Tags (1)
Labels (4)
2 REPLIES 2
Hi @Omer_Barr,
Thanks for reporting this. This appeared to be a bug on our end. It should be resolved now, so if you try to update the hub settings now, it should work.
Regarding the projects, that was also a syncing issue we had. Should also be fixed.
Let me know if you have any more issues 🙂
Martin Nordby Johansen
Software engineer at Autodesk Forma
Omer_Barr
in reply to: Omer_Barr
works perfectly. thanks!
