The area is outside map area ?
Bogdan_Chipara
Message 1 of 8
Bogdan_Chipara
What does this mean ?
Replies (7)
Message 2 of 8
arne.bassoe-eriksen
Hi @Bogdan_Chipara,
The error message tries to inform you that the area that you have specified is reaching outside of the map area. Here is an example of how this can happen:
To fix the issue, you will have to make the analysis area so that it does not cross outside the map area. You can do that in the right panel by clicking on the "+" sign to create a new analysis area. You will then be able to move the analysis area around on the map, change the size of the analysis circle and give it a name.
Tip: The analysis is actually using a larger area than the circle to create wind tunnels and give you more accurate results for the edges of the analysis circle. So try to make a good buffer from the edges of the map.
Message 3 of 8
Bogdan_Chipara
Thanks, I do understand what you mean, but still... Not working!
You see, the circle is inside the model, I reduced the radius...
I might do something that Spacemaker doesnt like...
Sun exposure works, and you can also see here the site boundaries.
Building footprints come from openstreetmap and I adjusted the max heights.
Message 4 of 8
mats.horsdal
Observer
Observer
Did you give your analysis circle a name? You will not be able to push the analyze button (the one below the slider) unless a name is provided.
Message 5 of 8
Bogdan_Chipara
I am able to push the analyse button. I just I dont get any results...
Message 6 of 8
mats.horsdal
Observer
Observer
Do you still get the "The area is outside map area" message?
Message 7 of 8
daniel.silva.gameiro
@Bogdan_Chipara , is the problem solved? I thought you could try to reduce the site limit.
Message 8 of 8
Could you let us know if you solved the issue? If so, what was the solution?
