Setback areas (Abstandsflächen GER)
l_mai9JPAK
l_mai9JPAK
Hello Everybody,
I am testing FORMA for potential analyses of proberties.  As our company is located in Germany, Abstandsflächen (setback areas) play an important role. Usally the distance is 0,4 of the building height. As seen here:
abstandsflächen 0,4 - Google Suche
Is there a tool in FORMA to see the setback areas?
Greeting from Leipzig
Lukas Mai
B&O Bau und Projekte
pal.most
Hi Lukas,
Thank you for reaching out.
Currently, we don't have explicit support for this.
The recommended solution would be to use the Measure tool and perform the calculations manually. You can learn more about the measurement tool
Thank you once again for your question. It's valuable feedback that helps us improve our product.
Best regards,
Pål Moen Møst, Engineer at Form Site Design
