Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Rhino plugin failed to push geometry
1 REPLY 1
DRIAJGXER
125 Views, 1 Reply
Hello all,
Some weeks ago I was able to easily play with the rhino plug in, loading context / terrain information in rhino with the forma link and push geometry back into forma with the geometry changes I wanted.
However, when I try to push geometry back into Forma now I receive this error "Unable to update element" after a while. See attached.
Am I missing something in the process? any suggestions?
Thanks in advance!
Labels (1)
1 REPLY 1
DRIAJGXER
in reply to: DRIAJGXER
For some reason, I tried again, this time I put the building to be pushed in the commercial layer and was able to push it to Forma. Then, I tried the same putting the object in a different layer and also worked just fine.
Not sure what was happening. 🙂 Thanks anyway.
