Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Revit Plugin-whether it functions in one direction only
0 REPLIES 0
Message 1 of 1
averylin
176 Views, 0 Replies
I have a concern regarding the Revit plugin. I would like to clarify whether it functions in one direction only. By this, I mean, if I load a proposal into Revit using the plugin, can I only use the update function to make changes to the model in Forma from Revit? In other words, is it not possible to edit the model in Forma and then reload those changes back into the same Revit file? Your clarification would be greatly appreciated. Thank you.
Labels (1)
0 REPLIES 0
