Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Revit Error when users don't have the Forma Add-in installed
3 REPLIES 3
caoimhe_loftus
337 Views, 3 Replies
Hi, we've imported context from Forma into a project - when other team members who don't have the Forma Add-in installed access the file they get the following error. Is this a known issue? Will this cause issues or does it just mean the project will be out of sync with the Forma model?
Caoimhe Loftus
Labels (1)
3 REPLIES 3
smilksh
in reply to: caoimhe_loftus
That's a great question.
Unfortunately, without the Add-in installed, Forma cannot track changes in the Revit file.  In other words, any changes made by a user without the Add-in will not be marked to send to Revit, even another user with the Add-in does the sync.
At this time, our recommendation is to the get the Add-in installed for all users who will be working on Forma connected Revit projects.
Thanks!
-Heather from Forma
caoimhe_loftus
in reply to: smilksh
Hi Heather, thanks for your reply. In this instance we've only pushed the context to Revit and we don't plan to update it. Is there a way to disable this error? The message mentions renaming the file?
Caoimhe Loftus
smilksh
You can use the "Unlink" functionality found with the Load and Update buttons in the Revit ribbon.
This will disconnect your Revit project from the Forma project so there shouldn't be error going forward (but keep in mind the connection will be gone).
-Heather from Forma
Forma Design Contest
Technology Administrators
