Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Revit Addin - Can't find data
3 REPLIES 3
kevin_fielding
176 Views, 3 Replies
I downloaded the addin for Revit via the forma window
Which downloaded 0.54 (this was the spakemaker version), When I tried to load from Revit it prompted me to install the newer version 0.56 (Forma Classic version).
When I click load in Revit I now get the following error / warning.
Is there another version of the addin available?
Kevin
Labels (3)
3 REPLIES 3
greg_marr
in reply to: kevin_fielding
Kevin, make sure that you're installing "Forma Revit Add-In.msi" and not "FormaClassicRevitAddIn.msi".
kevin_fielding
in reply to: greg_marr
I installed the classic version as this is the installer that was provided when it prompted an upgrade. Is there a link to the correct installer?
Thanks in advance.
The download now appears to have been updated for the Forma for Revit addin now which works.
Current version 0.8.2
Thanks for the fix.  👍
