Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Quick survey: Help the Spacemaker team with UI labels by answering a 2 question survey
6 REPLIES 6
elizabeth.yount2
257 Views, 6 Replies
Hi all!
The Spacemaker team is trying to understand the most meaningful label for a set of tools. If you'd like to help, please fill out the two question survey below:
Feature Label Survey
Thank you for your help!
Elizabeth
Labels (3)
6 REPLIES 6
Done!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Thank you Travis!!
ruyraoli
in reply to: elizabeth.yount2
Done! @marthe.brondbo
Você achou uma postagem útil? Então fique à vontade para curtir essas postagens!
Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão Aceitar Solução.
Rui Raoli
Eng. Civil Esp. em Design de Interiores e Iluminação | Gerente BIM
marthe.brondbo
in reply to: ruyraoli
Thank you for helping us out Rui!
Thank you for all your responses!
All done
Jonathan Hand
Technology Manager - Symetri Tech
 autodesk-expert-elite-member-logo-1line-rgb-black
twitterNaviate
