Hi @PetroGiancotti,
Our team is working with several data suppliers to increase data availability around the world. However, you can always bring your own data 😀There is a great article on this workflow in our help center.
I will try to summarize the basics:
Ensure your file is compatible
Import buildings (basic volumes/boxes without detailed architectural elements like windows OR meshes) and terrain separately.
Clean up overlapping geometries and gaps in plan and section
Georeference volumes.
If your model is not referenced you have 2 options:
a) Move your model to the coordinates provided in your BIM manual or a BIM coordinator;*
b) Export the site from Spacemaker (take note of the coordinate system you used in the export), import it to your software and move the whole project to the same location as the site polygon from Spacemaker.
*Some softwares like Rhino and Sketchup do not deal with coordinate systems and are just a neutral world, it is reliant on you basing your model on a file that is referenced. This means that if you e.g. import the drawing base sent from your map provider, that package is georeferenced in a specific coordinate system. If you then draw at that place and do not move those maps to 0,0,0 (origo), your model should be in the right location.
- Import the buildings to Spacemaker via the library menu accessible on the left-hand side of your browser.
Let me know if it worked! Have a good one and thank you for keep asking questions 🤗
