Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
missing button wind analyze interface information popup 4, can not continue to 5, 6 and 7?
4 REPLIES 4
AntonioCampanario
192 Views, 4 Replies
The last week of our trial period has arrived and there are still many questions left unanswered.
In the hope that the missing information could be found via the interface, I got stuck with the information for the wind analysis.
In the 4th (of 7) popup, the last line says: "click here to see the stations on the map." However, it opens an external web page, but no continuation to the 5th (of 7) popup is possible?
Perhaps i am looking at the wrong place, or this button has been "disabled" by accident, is it possible to guide me to the 5th popup or activate it again or add it so that the last popups can also be read?
Thank you in advance!
attachment: spacemaker interface info 4 can not continue to 5 - 6 and 7.jpg
Labels (2)
4 REPLIES 4
Thanks for reaching out!
The wind tour was indeed faulty, with a step that was not possible to complete.
I've removed the step you got stuck on, which should let you work through the remaining steps.
- Håkon
Håkon Matland
Principal Software Engineer
@AntonioCampanario, let us know if it worked!
Thank you for the quick action, i reached the end! 🙂
It worked, now i could reach the end of this tour 🙂
