Microclimate analysis problem
J_Jureidini
J_Jureidini
The issue is that I cannot "Edit" the location of the analytical area; it's stuck in one spot and I cannot shift it to the center of my model.
This is when I try to perform the Microclimate analysis function.
I can change the location of the analytical area if I'm analyzing the winds affecting my building; but it's not available in the Microclimate function.
per.wessel.noreCT6K6
Hi!
To edit the location of your microclimate analysis (and wind analysis) you can click the Analysis Area selection menu at the top of the right side menu, and then click "Custom Circle". Then you will be able to select the area of interest on the map.
Hope that helps!
Kind regards - Per
