I imported a Revit project into Forma, but the typical black contour lines are missing. The lines are visible in the Library's preview picture, but they do not appear in Forma's workspace.
I’ve imported almost the same model before without any issues, so this was unexpected.
Please see the pictures below comparing the new and old imports.
In addition to the missing outlines, the new import is also missing the gray "filling" of the objects. In other words, when the camera moves inside a wall, it appears hollow.
What could be the reason of this? I imported the model twice with the same result. The model is fairly large, containing 3717 parts, but I don't think that's the reason, as it worked last time also.
edit: I've also tried with another Forma project, but with the same result.
