Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Imported DXF not visible
9 REPLIES 9
Message 1 of 10
caoimhe_loftus
399 Views, 9 Replies
We've imported a dxf into a project but it's not visible except when we hover over it in the layer menu. Is this a glitch?
Caoimhe Loftus
Labels (1)
9 REPLIES 9
Message 2 of 10
Hello!
Yes - unfortunately we had some issues with rendering of DXF-imported geometry today. A fix was just deployed, so this should work as expected again. Let us know if you still see any issues.
Message 3 of 10
It seems we have the same problem, two days ago all was fine. When can we expect the fix to take effect?
Message 4 of 10
@leslieingFJ93F We apparently had two different problems around this. A fix has been deployed for both. Can you confirm things are working as expected again?
Message 5 of 10
Hey Henrik,
It was fixed, Hoewever the displayed line width is a lot wider than before. Best would be an option to control the displayed line width, if possible. The dxf is hard to read because of this.
Message 6 of 10
Was your DXF rescaled (e.g. change of units) after it was imported?
Are you able to provide a sample DXF file where you see a clear problem around this, which we can use to improve the experience?
Henrik
Message 7 of 10
I exported the drawing from autocad in 1:1 scale, and then imported in Forma in mm.
Message 8 of 10
I can reproduce the problem here. You can workaround it by exporting your DXF in meters (if that's possible, I'm not sure). We're looking into a proper fix, but not sure we'll be able to do so before Monday.
Message 9 of 10
Thanks for looking into it, Monday is perfect! In the meantime I will try exporting in different ways/sizes.
Message 10 of 10
@henrik_steenJL382 did this ever get resolved? I'm having a similar issue but am testing whether I can adapt the units within the dwg/dxf before exporting.
Caoimhe Loftus
