Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
how do i change the units from imperial system to metric in Forma?
3 REPLIES 3
Marthar_Kebirungi
242 Views, 3 Replies
3 REPLIES 3
Hi @Marthar_Kebirungi
You cannot change the unit system, but you can input the metric units in a project in the US. Try to type 25m as the width of the building, and you will see that Forma translates it tp the imperial system automatically.
Hello @daniel.silva.gameiro thank you for the insight. So should we assume that the unput units are determined by the region where US Hub is imperial while UK Hub is metric?
Hi @Marthar_Kebirungi , the unit system is determined by the project location, not a hub. The site used for the contest is in the US, thus the project is in the imperial system even for users based in Europe that have a European Hub.
Have you tried to input some values in the metric system and see how the software automatically translates it into the imperial one?
