How can I daw a pitched / sloped roof in Spacemaker?
PetroGiancotti
PetroGiancotti
Hi. Congratulations on the next-gen. I love it, but I am struggling to module a pitched roof on a line building.
Line building
Modeling with generic volume on top. I don't manage to add a node.
Also tried with 3D sketch, but couldnt draw a triangle vertically to extrude.
Can anyone help me out? Thanks
josh.goldstein
Hi @PetroGiancotti,
Happy to help! 3D Sketch is the way to go. 🙌
We've got a guide on this in our help center, which covers a few different approaches and scenarios, including:
  • This case (a building with a rectangular floor plan, for example created with the Line building tool in Design mode) via moving an edge up in 3D Sketch:
  • Other cases (buildings with irregular plans) via a powerful 3D Sketch tool called Tilt Face:
I'm assuming you want a more modern, asymmetrical pitched roof, and that's what the guide linked above covers. But I'm happy to follow up with how to create a more traditional symmetrical pitched roof as well, or you can see that covered in the latter steps here.
Enjoy!
Josh Goldstein
Senior Product Manager
daniel.silva.gameiro
Hi @PetroGiancotti,
In case you want to module an A-frame/ gable / double / 2 waters roof you can follow the steps below:
  1. Create 3D sketch
  2. Draw a polygon on top of the area you want to design the roof
  3. Select the surface and extrude it if you want the lowest attic floor to have some "vertical facade" before it tilts.
  4. Draw the roof ridge with the line tool and move the line up 😀
Watch the whole workflow in the video
(view in My Videos)
saeeddornajafi
Observer
Observer
Hello! I had a question related to this topic. Converting a building into a 3D sketch will give us the tools to create an "irregular" geometry. However, it looks like once the building is converted then the area metrics will not pick up the geometry. Is there a way around that? In other words, I'd like to take advantage of the design tool but also be able to do area take offs
josh.goldstein
Hi @saeeddornajafi,
3D Sketch buildings should definitely contribute to area metrics.
I'll direct message you - we'd like to access a copy of your proposal to investigate more closely, if you'll allow us.
Thanks for letting us know! Stay tuned for a message from me, and we can update this thread once we get a better idea of what's going on.
Josh Goldstein
