Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Geographic Coordinate System
4 REPLIES 4
stefano.tesotti
290 Views, 4 Replies
Hi, what geographic coordinate system does Forma use?
Labels (1)
4 REPLIES 4
Hi @stefano.tesotti once you load your forma proposal into Revit via the Revit add-in use the Location->Manager in the Manage tab under the Project Location panel.
I got this when I tested for Las Vegas, Venetian.
If this works for you, please mark it as a solution. Thank you.
Symetri Logo
Prateek Chitnis
Strategic Implementation Manager | AECO (Buildings)
facebooktwitterInstagrampm
If you don't have Revit, another way to see which coordinate system a Forma project uses is to export a proposal. The export will contain a readme file which states which coordinate system it is in (at least at the time of writing, the export is always in the same coordinate system as the project is internally).
Forma always (at the time of writing) uses a UTM coordinate system (with a WGS 84 datum) in the correct UTM zone for the location the project is in.
Trygve Aaberge
Software Engineer
@stefano.tesotti Did you find these solutions helpful?
Marthe
Thanks for the support.
