Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Features in Autodesk Forma
3 REPLIES 3
s12154361
267 Views, 3 Replies
Hi
Is the view Analysis and Noise Analysis available in the Autodesk Forma version?
Note: this post was revised after the rebranding from Spacemaker Next-gen to Autodesk Forma
Labels (2)
3 REPLIES 3
Hi!
Noise - We are currently working on bringing the noise analysis for traffic to Next Gen, but it is not available just yet.
View - We have not looked at the view analysis yet. Which of the two view analysis did you find most valuable?
Kind regards, Per
It would be good if we add view analysis with the ability to add any surface as a target area. In Classic version only allow ground level surface as view target.
We have project, required to analyse the view from new building to iconic existing building,.
I understand. We will take it into consideration going forward.
Thank you for raising the need.
