Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Entire model turned blue
2 REPLIES 2
Blue_Team
158 Views, 2 Replies
I've been working on a proposal and the entire model has turned blue, buildings, vegetation, generic models, all of it. When I turned on and off visibility for objects I can see the function colors briefly and then they switch back to blue.
Not sure what I did or how to undo it. Thoughts?Screenshot 2023-04-20 112854.png
Labels (1)
2 REPLIES 2
hilde.bakkeli
in reply to: Blue_Team
Hi!
That sounds like too much blue!
Did you try some of the analyses when this happened? The analysis selection menu highlights the objects you have chosen within the site limits or zones you have selected - in blue. Could you try f ex sun hours analysis, open the selection menu at the top to turn off selected analysis areas to see if this affects the blue?
Hilde
Hilde Bakkeli
Product Manager
hilde.bakkeli
An update on the blue issue: It appears we had a temporary problem for a few hours yesterday, causing a lot of blue to appear even when the analysis selection menu was not opened. This issue should now be resolved. Please try again - hopefully there will be less blue this time!
Hilde
Hilde Bakkeli
Product Manager
