Detail Wind Analysis is an endless process.
ehsan_omidHTLEZ
ehsan_omidHTLEZ
rapid wind study works perfectly well however when I try detail wind study, the process never ends. is it available only for some countries now?
maxime_briens
Hello! Thank you for reaching out.
I am not sure how long exactly you have been waiting, but as you can see in this help article, the wind analysis is a Computational Fluid Dynamics (CFD). This means that it is a full scale numerical simulation of your site resolving fluid dynamics equations at each points. In other words, it is normal for this analysis to take around 1 hour.
As this takes a while, it might be easier to access the analysis using the history (underneath the button to trigger the detailed wind analysis). From here you can access the latest analysis or the history of the previous ones you ran on the same proposal.
See this screenshot for reference.
This is also because the detailed wind takes such a significant amount of time that you can access, as a faster alternative, the rapid simulation. It uses AI to estimate wind results and help you iterate much faster.
Let me know if you need any additional help!
daniel.silva.gameiro
Hi @ehsan_omidHTLEZ,
Did you get a detailed wind analysis?
justinechile.panopio.archi
Community Visitor
Community Visitor
its been 10 hours and i still haven't got the detailed wind analysis. what to do?
