Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Control floor number and floor height in 3D Sketch
5 REPLIES 5
ThitipatP
207 Views, 5 Replies
I wonder that how can I change the floor number and floor height in 3D sketch. Anytime I changed, the program will switch to default (3m floor height). I tried to lower the floor number and increase the floor height, not work. Please advise
Thank you
Tags (2)
Labels (1)
5 REPLIES 5
josh.goldstein
in reply to: ThitipatP
Hi @ThitipatP,
All floor height and floor quantity inputs seem to be working for me in 3D Sketch.
Would you mind recording a video of the issue?
Thanks!
Josh Goldstein
Product Lead
Here is my screen capture.
Thank you
Tags (1)
Thanks, that was really helpful!
I'm able to reproduce now. It seems the nuance is not entering a unit after the number.
As a workaround, can you try entering 4m instead of 4, for example? See if that works for you.
In the meantime, we'll get the issue with entering a number only (no units) fixed.
Josh Goldstein
Product Lead
Hi
Thank you, It's works now. I tried to entering suffix as m or mm, these both works.
Hi @ThitipatP,
We've now fixed this issue, so you can return to using numbers without the unit, and 3D Sketch will append the unit automatically.
Thanks for letting us know about this! 🙌
Josh Goldstein
Product Lead
