Autodesk Forma - Saved Views
eklingerHFVZ3
Message 1 of 24
eklingerHFVZ3
I am in the process of creating some analysis studies for a master planning effort and am realizing there does not seem to be any way to create and save views for repeated image exports like there was in the previous version of space maker. Is this a planned feature for Autodesk Forma?  Without it it will be very inconvenient having to export all images at one time to ensure continuity and/or trying to match the perspective when exporting images at a later date.
Note: this post was revised after the rebranding from Spacemaker Next-gen to Autodesk Forma
Accepted solutions (4)
Replies (23)
Message 21 of 24
crowneng-emirates
My export camera is disabled I have been trying for a day now to enable it wether in analysis or design mode It does not work any idea why
Message 22 of 24
hilde.bakkeli
Sorry to hear the camera is not working for you.
What browser are you using? Could you send a snapshot to show the problem?
Hilde
Hilde Bakkeli
Product Manager
Message 23 of 24
julianL2LWH
Good morning, everyone. I'm new to the platform, and I'd like to ask if there's a way to export the images with labels generated from Forma. I can see them from the workspace but I'd like to be able to show them in an exported view.
Thank you for your help and looking forward for all the upcoming features and improvements.
Message 24 of 24
josh.goldstein
Hi @julianL2LWH!
It's true that labels don't seem to show up when using "Vector (SVG)" but if you choose "Screenshot (PNG)" from the drop-down, you should see the labels. If SVG isn't a hard requirement for your use, can you try PNG?
If you're already setting it to PNG and still not seeing the labels, maybe this is a specific case we need to investigate. I'm not sure why labels aren't showing for SVG, but at least there should be a workaround.
It might be worth posting this as a new topic in the future so other customers who might have the same question can find the answer a little easier. 🙌
Thanks for writing in!
Josh Goldstein
Senior Product Manager
