Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Alternative Methods for Noise Analysis and Wind Simulations in Forma?
3 REPLIES 3
ertunchunkar
330 Views, 3 Replies
I'm encountering an issue while trying to run the 'Noise' analysis in Forma for my project. The analysis requires me to define roads with traffic data, but even if I add the roads from OpenStreetMap, I'm still unable to proceed. The error message states, 'Please add roads with traffic data in order to run the Rapid Noise analysis.' I'm curious to know if there are alternative methods to run this analysis, considering that incorporating external traffic data is not currently possible in Forma.
Furthermore, I would like to inquire about the possibility of enhancing wind simulations in Forma. Currently, wind direction visualization is limited to 45-degree intervals. Are there any plans to provide more precise wind simulations in the future?
Thank you!
3 REPLIES 3
averylin
in reply to: ertunchunkar
regarding the noise analysis issue you mentioned, I guess that the OpenStreetMap data might not include road data. Therefore, you had to manually draw a road on the map and input the necessary data for that road. By doing so, you were able to successfully obtain the analysis result. This is what I did. FYR
ertunchunkar
in reply to: averylin
Thanks for your reply! It helped me to run my first noise analysis. The problem with the imported roads, is that they're directly imported under "Base". After you imported the roads, if you click "Edit" on "Base", then right click on "Roads" and then click on "Move to Proposal", the roads can be defined with traffic data.
Best,
Ertunc
averylin
thank you for sharing this with me. It answers my long-term confusion regarding how to use the imported road. I appreciate your help and guidance.
Technology Administrators
