Parking insert into DWG (Autocad) , with cores marked.
namih99
namih99
Community Visitor
Community Visitor
Hi, I would like to upload a DWG file with the cores marked and generate an optimized parking layout based on specific stall sizes and design parameters. Could you please let me know how this can be done?
Ingrid_Lew
Hi @namih99
For parking layouts in Forma, you have two main options:
Inside buildings: Create a Basic building, select it, choose a floor plan in the right-hand panel, then add "parking" to generate spots within units. You can adjust stall width (2.5m default), length (5m default), angles, and lane widths. Read more here.
Ground-level parking: Use the TestFit extension to draw parking on terrain. It lets you customize stall width, depth, drive aisle width, and other parameters with sliders.
However, Forma doesn't directly import DWG files with marked cores for automatic parking generation. You'd need to recreate your layout using our building tools and parking features. Read more here.
Ingrid L
namih99
Community Visitor
Community Visitor
Thanks for you reply.
I tried Testfit extention. I am trying to add manually the cores. with no luck. Can you please write me how? and another question. Is the number of parking lots optimaized (I get the max places)?
Ingrid_Lew
Hi @namih99 With the TestFit extension, you can adjust parameters such as orientation, stall width, depth, and turning radius. However, it is not currently possible to add cores manually. The number of parking spaces is automatically optimized based on your parameter settings.
Ingrid L
