I have two questions regarding Forma’s wind and microclimate analysis.
- I understand that Forma uses OpenFOAM with the simpleFoam solver for CFD component and applies Atmospheric Boundary Layer (ABL) conditions for detailed wind analysis. I was wondering what the initial condition for wind velocity is. Is it assumed to be 3 m/s, or if ERA5 data is used, which data is considered for U? Does it take the average value over eight years (2013–2020), or another period? Also, are the results tied to a specific time of year or a particular year?
- I assume that the results from the detailed wind analysis are also used for the microclimate analysis. If that is the case, and the wind analysis is run under steady-state conditions, how does the microclimate analysis produce UTCI values for different hours between 8 a.m. and 8 p.m.?
I appreciate your help in clarifying these points and helping me better understand the workflow.
Thank you!
