Compare mode crashing
adam_ulvesonP6JQU
adam_ulvesonP6JQU
When using Compare mode I often (almost always) get this error message : Your computer does not seem to support WebGL, which is a requirement for using Forma
I have colleagues with the same problem.
I have tried following the instructions before (now the link is dead). I have been in contact with Forma support and my company IT support (we have a tight partnership with Autodesk and the Forma team). Still no luck in fixing this. It has been like this for a long time. Anyone elese having the same problem. Any known fixes?
vilde.barth
Thanks for reaching out. This sounds very frustrating.
Are you just experiencing the issue in Compare, or other applications like Site Design, Analysis and Board as well? Have you noticed if it happens when viewing a particular analysis type or if it happens with all?
Best regards,
Vilde Barth
martin_hedin
I have the same issue. The same problem in Chrome and Edge. It happens when comparing noise simulations.
vilde.barth
To understand the problem better, can you share a screenshot or recording of when it is crashing? Feel free to send it in a direct message if you have confidential information in your project that you do not want to share in the forum.
Best regards,
Vilde Barth
vilde.barth
We have recently discover and fixed an issue which we believe is related to the problem you reported. Sorry that it took some time, but hopefully it is working for you now. If not, let us know!
Best regards,
Vilde Barth
vilde.barth
