Microsoft BI
Microsoft BI
kbaerQEX4N
Microsoft BI
kbaerQEX4N
So ACC really pushes Microsoft Power BI as tool to use and I have been playing around with it.  And one of the tings that I've run run into is that the forms that my company uses on builds and, in turn get collected by the Data Collector and used for the Power BI cards doesn't seem to be formatted in a way that likes to talk to Power BI.  The cards kind of work?  Are there any rules that I should be following when building report and RFI templates to make it easier for for BI to talk to?  Any tips for using BI in general?
lance.borst
Hi Kevin,
RFIs or simply any template in general a good starting point is for you to check out the schema folder that is provided when they download the data extraction in the data connector log window. There you can see what each field is and how to connect each table service they are interested in pulling. I'm searching for a link to a another document that will break down extracting data from a  smart pdf.
kbaerQEX4N
Thank you sir, I appreciate the information.
