Insight builder analysis sheet - to be deleted
Anna_Pawlewska_TFK
Anna_Pawlewska_TFK
Hi everyone,
I've been exploring the Insight Builder and overall, it's been a great experience so far. However, I’ve run into one issue I haven’t been able to solve on my own: I can’t find a way to delete sheets from an analysis.
I’ve created, copied, and modified several sheets during testing, but now I’m left with a few that are no longer needed—and there doesn’t seem to be an option to remove them. Has anyone found a workaround for this? Or is there a chance we could see a “Delete Sheet” button added in a future update? It would be incredibly useful!
Thanks in advance for any tips or insights!
Anna_Pawlewska_TFK
It turns out there is a way to delete sheets from an analysis, though it’s not very obvious at first. I’m sharing it here in case it helps someone else in the future:
You need to rename the sheet first, and then right-click on it—this will give you the option to delete it.
Hope this saves someone a bit of time!
