Import from BCF’ Option Missing in Model Coordination Issues (ACC)
We are getting started with setting up BIM-coordiantion workflows, since we just started we had the choice to work with only Autodesk products or chose OPEN BIM principles as much as possible, we choose the last option.
Now i wanted to try the workflow where we export a BCF file from Solibri office or Navisworks (should be possible with a add in i think).
See my question below, thank you for reading !
📌 Forum Question – “Import from BCF” Option Missing in Model Coordination (ACC)
Environment: Autodesk Construction Cloud Subscriptions / Modules:
Autodesk Docs
Autodesk BIM Collaborate (Design Collaboration + Model Coordination)
Full Admin rights on both project and account level
Models in Coordination Space: IFC + RVT
Issue Description
I am trying to import issues using a BCF file in Autodesk Construction Cloud (Model Coordination).
According to Autodesk’s documentation (https://help.autodesk.com/view/BUILD/ENU/?guid=Issues_BCF_Import) , the option “Import from BCF” should appear under the three‑dot menu in:
Model Coordination → Issues
However, in my project:
The three‑dot menu does not appear at all in the Issues tab
Therefore, the BCF import option is missing
The page only shows: “No issues found in coordination space”
In the 3D viewer I do see a three‑dot menu, but it only contains:
Export PDF
Export XLSX
What I Have Already Checked
✔ A Coordination Space is active
✔ The correct folder is linked to the Coordination Space
✔ An IFC model is present in that folder
✔ I added an RVT model as well (to ensure clash detection is possible)
✔ I have full admin permissions
✔ Model Coordination module is enabled
✔ I am opening Issues from Model Coordination, not from Docs or Build
✔ Models appear correctly in the Coordination Space
Despite all of this, the BCF import option still does not appear.
My Question to the Community
Has anyone experienced a situation where:
A Coordination Space is correctly configured
Models (IFC + RVT) are indexed
Admin rights are confirmed
Model Coordination is active
…but the three‑dot menu and “Import from BCF” option still do not appear in the Model Coordination Issues tab?
Maybe i am in the wrong and is this not an option with ACC Model Coordination (al the names and subscriptions are getting quite confussing )
Are there additional conditions, hidden requirements, or known bugs that could cause this behavior?
Any insights or experiences would be greatly appreciated.
Thanks !!
