Autodesk Forma Document Management – Multi-Level Sorting by File Format and File Name
In alignment with our clients’ requirements, we often manage multiple file formats within the same folder. We have received several requests from project teams for the ability to sort files using two levels of sorting, for example:
File Format → File Name
At the moment, we do not see this option available in Autodesk Forma Document Management.
Our current workaround is to create and maintain a custom attribute for file format and then sort based on that attribute. However, this creates additional administrative work, as responsible team members must manually populate and maintain the extra field.
Adding native multi-level sorting, such as File Format → File Name, would make file navigation significantly more efficient and improve the user experience, especially in folders containing a large number of mixed file types.
This is a basic feature that is available in many common file management tools, including Microsoft Windows File Explorer, and it seems like it would be a valuable and straightforward enhancement for Autodesk Forma Document Management.
Has anyone found an alternative solution, or is this functionality already being considered for a future release?
