Autodesk Desktop Connector
Moshe-A
Mentor Mentor
Moshe-A
Guys Hi,
Hope i am in the right forum 🙏
On one side the Autodesk Desktop Connector says "Everything is up to date" on the other hand
all folders are still under syncing - see picture
Can someone shade some light on that?
thanks in advance
phd1138
your pic with the image showing still syncing is missing.
Jamie.Headley
You can try troubleshooting the syncing project through the menu in the screenshot.
Alternatively you can disconnect the project, under "select projects", then reconnect to the project.
This should fix any files stuck syncing.
andr3sant0s
Hi @Moshe-A
I guess you encountered this error after trying to upload a significant amount of information in bulk, right?
I suggest looking at this page with the best practices for using desktop connector.
https://help.autodesk.com/view/CONNECT/ENU/?guid=Best_Practices_16
I know that there's a new version coming out soon that hopefully will address this kind of errors.
Please use Accept as Solution and like/Give Kudos as appropriate to further enhance these forums.
