Forma Developer Forum
Welcome to Autodesk Forma Developer Forum. Share your knowledge, ask questions, and explore popular Forma API topics.
How to place a library item on the Canvas?
2 REPLIES 2
iklimis
232 Views, 2 Replies
Hi Forma Team,
Using the following code I have successfully uploaded and created a Library item (a glb file)
I am having some trouble however to place it the canvas using code
Could you give me a working example of code of how to place this library item for example at the center of the project area??
That would help a lot
Thank you
Giannis
    const { fileId } = await Forma.integrateElements.uploadFile({ data: glbArrayBuffer });
    const { urn } = await Forma.integrateElements.createElementHierarchy({
      data: {
        rootElement: "root",
        elements: {
          root: {
            properties: {
              geometry: {
                type: "File",
                format: "glb",
                s3Id: fileId,
   const item = await Forma.library.createItem({
     data: { name: "Pin", status: "success", urn}
the above code produces a Library Item such this:
    authContext: "pro_ewbhpcg7dp",
    status: "success",
    updatedAt: 1707408884692
    urn: "urn:adsk-forma-elements:integrate:pro_ewbhpcg7dp:50473c19-ef39-4e88-b18f-5ce209e5ecfa:1707408884129"
Labels (1)
2 REPLIES 2
magnus.poppe.wang
in reply to: iklimis
Hi there!
You are on the correct path! After creating your element with integrateElements, you can use the Forma.proposal.addElement() function to place your element into the scene. The URN you've used for adding a Library element can be used with the addElement() function. Note that the transform property decides the placement of this element relative to the local origin of the project.
You don't need to add the element to library for placing the element into the scene.
Can't wait to see what you're up to during the hackathon next week! Hope this helps, and let me know how it goes 😊
iklimis
in reply to: magnus.poppe.wang
Thanks a lot @magnus.poppe.wang !!
Worked very well!  Missed the addElement() method of the proposal Api - it is quite helpful..
Would have been nice if the Glb maintained the colors of the file during the upload. I suspect there is some kind of compression happening there ?
Cant wait to meet you guys on Tuesday!!
Giannis
