Forma Developer Forum
Welcome to Autodesk Forma Developer Forum. Share your knowledge, ask questions, and explore popular Forma API topics.
How to alternate between textures?
3 REPLIES 3
iklimis
248 Views, 3 Replies
Is there a way to load a specific texture that has been previously loaded without creating and adding a new canvas element.
Currently when I create two textures and I want to alternate between them, I have to create a canvas for each one from the start.
Is there a more convenient, efficient way for example loading a texture using just the texture name?
Tags (1)
Labels (1)
3 REPLIES 3
havard.hoiby
in reply to: iklimis
Hello 🙂
There is no mechanism at our end for storing and loading the texture. You would need to do this inside the extension. Here is an example of how to create to canvases ahead of time and then just swap between them on a button click:
import { Forma } from "https://esm.sh/forma-embedded-view-sdk/auto"
const canvas1 = document.createElement("canvas")
canvas1.width = canvas1.height = 100;
const ctx1 = canvas1.getContext("2d")
ctx1.fillStyle = "green";
ctx1.fillRect(0, 0, 100, 100);
const canvas2 = document.createElement("canvas")
canvas2.width = canvas2.height = 200;
const ctx2 = canvas2.getContext("2d")
ctx2.fillStyle = "blue";
ctx2.fillRect(0, 0, 200, 200);
document.getElementById("c1").onclick = async () => {
  await Forma.terrain.groundTexture.add({
    canvas: canvas1,
    position: { x: 0, y: 0, z: 1000 },
    scale: { x: 1, y: 1 },
document.getElementById("c2").onclick = async () => {
    canvas: canvas2,
I would also suggest the newly added storage api under `Forma.extensions.storage` here you can store and load named objects. This way a user their texture and then load it afterwards from our servers. The docs for this is on the way but a gist of the usage is:
Forma.extensions.storage.setItem
Forma.extensions.storage.getBinaryItem or getTextItem
There is an example on its way which uses it here: https://github.com/spacemakerai/forma-extensions-samples/pull/13/files
Does this answer your question? And importantly are you asking this for convenience or have you uncovered a performance issue?
iklimis
Thanks for your reply! I had imagined that such a solution would be more likely.
the new storage api is most helpful btw
havard.hoiby
Great that you find it useful.
The docs are now available here: https://aps.autodesk.com/en/docs/forma/v1/reference/embedded-view-sdk/extension-storage/
Forma Design Contest
Technology Administrators
