Forma Developer Forum
Welcome to Autodesk Forma Developer Forum. Share your knowledge, ask questions, and explore popular Forma API topics.
Forma Analysis Constructions list retrieve from the API
2 REPLIES 2
mjovic
194 Views, 2 Replies
Hi I am trying to get the roofs, walls and windows constructions list. I also need the window-to-wall ratio. How can I do that from the forma API ?
2 REPLIES 2
hakon.matland
in reply to: mjovic
Hi @mjovic .
It is currently not possible to retrieve the input parameters of the rapid operational energy analysis through our APIs.
To further understand what you'd like to do: Is it the parameters of the rapid operational energy analysis in particular you are interested in, or that type of details in general?
As an example the embodied carbon analysis (technical preview) has similar configuration, but on a per building level.
Those are not exposed through APIs either, but is something we know about other use cases for as well.
Håkon Matland
Principal Software Engineer
mjovic
in reply to: hakon.matland
Thank you for your answer. We are analyzing the building from the energy point of view. In that case we need the data to set them as the initial values in our calculations. For now I can just hardcode that data but in the future would be good for us if we can have the real data from the API.
Technology Administrators
