Forma Developer Forum
Welcome to Autodesk Forma Developer Forum. Share your knowledge, ask questions, and explore popular Forma API topics.
File Explorer example files for upload
1 REPLY 1
trevor_scullion
243 Views, 1 Reply
I had some issues with the Forma API code example "file explorer" and the uploads not working with my project. The readme file recommended getting test files from https://kenney.nl/assets/city-kit-suburban  but those files cause errors and never upload. Uploading any of those files to the gLTF validator on   shows the errors. I've tried other GLB files (that validate fine) and the file explorer demo works fine so I'm up and running on what I was trying to do.
Just an FYI for any devs out there trying that example and hitting a 'wall'.
Labels (2)
1 REPLY 1
Hei:
Thanks for reaching us. We have added a stricter validation for uploading `GLB` file. Thats the reason the upload is failing. Also according to the https://registry.khronos.org/glTF/specs/2.0/glTF-2.0.html#glb-file-format-specification.
The root node cant referenced by any other node. Thats the actual reason its failing. Maybe you can try with this example https://kenney.nl/assets/platformer-kit.
Md Amjad Hossain
Software Development Engineer
Forma Design Contest
Technology Administrators
