Forma Developer Forum
Welcome to Autodesk Forma Developer Forum. Share your knowledge, ask questions, and explore popular Forma API topics.
extensions.invokeEndpoint() fails for content type "application/json; charset=utf-8"
3 REPLIES 3
vkokkinidis
194 Views, 3 Replies
Tried calling Forma.extensions.invokeEndpoint() towards a backend service that returns "application/json; charset=utf-8" as content type.
The network call is successful, but the extension emits an error saying it's unsupported.
Do we have to explicitly return 'application/json' ?
Thanks!
Labels (1)
3 REPLIES 3
Hello!
The media type of "application/json" does not define any optional parameters [1] such as charset. The standard also requires the use of UTF-8 [2].
Are you able to remove the charset parameter?
[1] https://datatracker.ietf.org/doc/html/rfc8259#section-11
[2] https://datatracker.ietf.org/doc/html/rfc8259#section-8.1
Henrik
We've deployed a change now to not be too strict on our side for this checking. Your original content-type value should work now for this case. Note that the exact charset specified will be ignored (always parsed as UTF-8).
Let us know if you see any more problems around this.
Henrik
Thank you for your speedy fix.
The backend service is a boilerplate asp.net core (.net 6 framework).
Apparently, Microsoft insists on automatically appending a 'charset', although against the standard as you pointed out.
Handling it on your side is very helpful.
Cheers!
