Embedded view with APS Viewer
paolo_serra
Autodesk Autodesk
paolo_serra
Hi, I'm trying to test it is possible to have an embedded view with an ASP Viewer.
When I reach the page from the browser I get the intended view (nothing fancy)
but when I try the same in the embedded view I get this
The viewer is stuck and does not load the model. What could be the reason?
Paolo Emilio Serra
Principal Implementation Consultant
Solution Innovation Lead
Global Consulting Delivery | Customer Success | Autodesk
henrik_steenJL382
We need some more details to be able to assist you. Have you checked the browser console or the network tab for any issues?
I tried to follow https://aps.autodesk.com/en/docs/viewer/v2/tutorials/basic-viewer/ and it worked on the first attempt here inside an extension.
marthe.brondbo
@paolo_serra  -Did you find a solution to your problem?
All the best,
Marthe
