GRAPH SHOWING LIFT ALONG WITH DRAG
It would be a helpful addition if we could get lift values and lift graphs along with drag. I was surprised not to see such a utility in a software developed for wind tunnel testing of models. It would be of immense use especially when it comes to automobile and aircraft based models..
25 Comments
TD-Thinnov
Community Visitor
Not only lift factor is important. If the pressure point could be included to that would also be very helpfull. I'm also surprised that it isn't yet implemented.
Reebsmith
Community Visitor
I totally Agree with you!
gstewart
http_abdulmoiz
Community Visitor
Unfortunately, as a text-based AI, I am unable to generate visual graphs directly. However, I can describe to you the general relationship between lift and drag and how they are typically represented in a graph.
In aerodynamics, lift and drag are two important forces that act on an object moving through a fluid, such as air. The lift force is perpendicular to the direction of motion and acts in an upward direction, while the drag force opposes the motion and acts in the opposite direction.
Typically, a graph showing the relationship between lift and drag is known as a lift-drag polar or a drag polar. It is a plot that displays the varying amounts of lift and drag for different operating conditions of an object, such as an aircraft or an airfoil.
The graph usually has lift coefficient (Cl) on the horizontal axis and drag coefficient (Cd) on the vertical axis. The lift coefficient represents the lift generated by the object, while the drag coefficient represents the drag experienced by the object. The coefficients are dimensionless values that are normalized based on the object's characteristics and the properties of the fluid.
In the lift-drag polar graph, data points or curves are plotted to represent different operating conditions or angles of attack. The curve for a specific object shows the relationship between lift and drag for that particular configuration or airfoil shape. The shape of the curve helps in analyzing the aerodynamic performance of the object, such as its efficiency or the stall characteristics.
Generally, at lower angles of attack, the lift increases with an increase in the lift coefficient until it reaches a maximum value (known as the critical angle of attack). Beyond this point, the lift may start to decrease, and the drag tends to increase significantly. This region is often referred to as the stall region.
The lift-drag polar graph provides valuable information for understanding the aerodynamic behavior of objects and optimizing their performance. It assists in determining the best operating conditions to achieve maximum lift with minimum drag, which is crucial for efficient and safe flight.
If you are looking for specific lift-drag polar graphs for a particular object or airfoil, it would be helpful to consult aerodynamic references, textbooks, or specialized software that can generate such graphs based on specific parameters and conditions. how to camp with a dog
mirza278ahmed
Yes, I agree with you because optimizing vehicle aerodynamics improves the efficiency of fuel and stability of the vehicle. Including lift values and lift graphs alongside drag in a wind tunnel testing software would be a game-changer
