Flow Design Forum (Read Only)
Welcome to Autodesk’s Flow Design Forums. Share your knowledge, ask questions, and explore popular Flow Design topics.
Standalone version and wind direction
3 REPLIES 3
dhurtubise
880 Views, 3 Replies
I dont seem to be able to adjust the wind dirction in the standalone version
3 REPLIES 3
Royce_adsk
in reply to: dhurtubise
Have you tried working with the orientation controls?
http://help.autodesk.com/view/ADSKFD/ENU/?guid=GUID-081C69D1-F003-4ACD-9DB8-7451B5B431D6
Best regards,
Royce.Abel
Technical Support Manager
dhurtubise
in reply to: Royce_adsk
Just tried, it allows to rotate the model but the plane stays the same.
Having loaded an FBX im stuck with no way to tell north from South this way.
But i do get to rotate the mode l:)
cahtasham55
To confirm this, just do three sample plots using HPCONFIG to set the
quality. Then compare the output. You should see a big difference between
at least two of them.
Hope this helps. Thanks
